The following table defines parameters for the dvr controller vrrp-on-dvr-isids priority command.
When a Layer 2 Virtual Service Network (VSN) extends outside of the DvR domain, DvR Controllers can route traffic that enters on the network-to-network interface (NNI) by using Virtual Router Redundancy Protocol (VRRP).
The VLAN must be a DvR VLAN. A DvR VLAN is a VLAN configured on a DvR Controller with a VLAN IP address, a VLAN I-SID, the DvR gateway IP address, and DvR enabled.
If you enable this functionality, the switch automatically creates a VRRPv2 interface with the virtual router ID (VRID) 37 and a holddown-timer configuration of 60 on the DvR VLAN that you identify for VRRP election. You can configure one VLAN for election.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Enable VRRP election on the DvR VLAN:
    dvr vrrp-election
  3. Exit to Global Configuration mode:
    exit
  4. Optional: Configure the DvR VRRP priority for the elected VLAN:
    dvr controller vrrp-on-dvr-isids priority <1-254>
  5. Enable VRRP advertisements on all DvR VLAN Service Instance Identifiers (I-SIDs):
    dvr controller vrrp-on-dvr-isids enable
Variable
Value
<1-254>
Configures the Virtual Router Redundancy Protocol (VRRP) priority for the elected VLAN and associated Service Instance Identifier (I-SID). Switches advertise their priority to use in the primary router election process. When multiple Controllers elect the same DvR VLAN and I-SID, the Controller with the higher priority becomes the primary router. The elected Controller sends VRRP advertisements on all DvR VLANs.
The default value is 100.
